ir 3530 code E355
  • faisal jilani
    saad jilani
    • Sep 2008
    • 40
    ir 3530 code E355
    hi,i have one Ir 3530. this machine i think so some one change the counter PCB.now machine showing code E 355- 01 how to clear this code thanks
  • cdtw9803
    • Aug 2009
    • 51
    CLEAR IT IN SERVICE MODE. *,28.*,copier,function,clear,E355,OK
    • montana
      • Aug 2008
      • 392
      hi....go into service mode additional function-28-28 -additional function
      then select function then toch clear then ok & restart
      good luck .........regards
      • nivssluck
        • May 2008
        • 228
        I don't think so if you can CLEAR this error....
          • 23010
          Most likely, this is not the original counter PCB serialized to another machine. You'll have to get the original counter PCB serialized to this machine, or contact Canon for a replacement.
          • SCREWTAPE
            • Aug 2025
            This is absolutely correct.
            • SCREWTAPE
              • Aug 2025
              To clear an E355 code, you must access Service Mode Level 3.
              So its more than just doing a *28* there more to the sequence
              for level 3.
              • alex@wocltd.com
                • 430
                but it wont clear that code if it has the wrong boards on it - it's a controlled part and someone has done something fishy or smelly....
                • cdtw9803
                  • Aug 2009
                  • 51
                  I can make sure that E355 is a problem of serial number board which with no parts number . you have to order a new one through a authorized service station.
                  or i can help you.
