help
  • bomberi
    • 107
    help
    to all i want help
    I need system for canon ir2200 err E062-01 thanks
  • nivssluck
    • May 2008
    • 228
    I have for $20..
    • SCREWTAPE
      • Jul 2025
      Originally posted by bomberi
      to all i want help
      Do you mean E602-0001?
      This error is associated with your HDD,
      it may be faulty. You might need to replace it.
      • bnmand
        • Sep 2008
        • 383
        First thing to try is to turn copier off using main power switch (on right hand side). Turn it back on while holding down 1 and 9. You should see some rectangles on the screen and eventually Download mode. Try reloading firmware using SST (if you have SST and firmware). If this doesn't work you'll need to change the hdd.
          If the copiers showing a black screen with E602-0001 in the top left wouldn't 2+8 download mode work better as it bypasses the user interface?
          • nivssluck
            • May 2008
            • 228
            E602-0001 HDD is dead or not present. You have to reformat it and load system or else buy new one. I have HDD for $500 only
            • JustManuals
              • Jan 2006
              • 9838
              Good price, if I were you I'd jump on it before the price goes up or he changes his mind.
              • bnmand
                • Sep 2008
                • 383
                With just a little bit of knowledge, namely how to edit the HDFormat.ift file you can use some hdds that are much cheaper than that.
                • cdtw9803
                  • Aug 2009
                  • 51
                  if you can enter diagnostic mode ,the hdd can be recovered easily.
                  if the hdd runs with bad noise, you have to replace a new hdd.
                  perchasing a new hdd from canon is very expensive, so you can buy a normal ide-mode hdd and setup a new system in it .
                  by the way, is the ir2200 with a NIC? the system is different if ir2200 is not with a NIC.
                  • bomberi
                    • 107
                    help
                    good I've seen all your helps, the first I have done the scanning hdd and by the finish it make download so I think that the firmware is no present.
                    I have some firm and sst but I h'nt for ir3300. if you can help me do this for god and not for money .THANKS
