Printer Board IR600 can't print - REPOST
  • bnmand
    • Sep 2008
    • 383
    This is a repost for oketee. The occassional problem where a thread comes up in a read-only print version has reoccurred.
    Originally posted by oketee
    Hi all, I have some problem about printer board IR600. It can't print. When I print it, it show "wait" and reboot... (But can print config.) I tried to reinstall and change Ram. It doesn't work.
    Thanks..
    My answer: Re-install firmware on the pdl board using the PDL downloader. You will need to hook up to the parallel port on the PDL board to load the PDL firmware.
    Can also try reloading copier firmware on hdd or replacing hdd and installing firmware onto that. Note you will need to use sst and the normal parallel port (not the PDL one) to install copier firmware.
  • bnmand
    • Sep 2008
    • 383
    Someone may have the pdl downloader and firmware. Use bi-centronics IEEE1284 parallel cable.
    • okeetee
      • 16
      I used PDL downloader to re-install. But it doesn't work. When i print it reboot...i don't know why? May be my board broke.
      • THUK
        • Jul 2008
        • 195
        have you run this from a laptop with crossover cable-im thinking ip issue.also have u tried all clear-dccon mncon and mmi.
        • davidj7
          • 1107
          where you able to complete reinstall using pdl. Did you put the machine in install mode before initiating pdl install.
          I ve had similar problems but was fixed after reinstall.
          a machine is only as good as your tech : source:screwtape ; the scary one
          • cdtw9803
            • Aug 2009
            • 51
            i met a case like you did but on IR 400, luckly within 1 year, I ordered a free print card.
            • bnmand
              • Sep 2008
              • 383
              The IR600 is a really, really old machine and thus while you can use a crossover cable to test printing it can't be used to install firmware.
              • SIDDHARTH
                IR 600 System Software
                Download link for canon IR 600 System Software
                • Canontech
                  • Aug 2009
                  • 16
                  The 600 firmware ain't going to do jack. You need the EFI firmware. Good luck trying to find that.
                  • nivssluck
                    • May 2008
                    • 228
                    Changing the HDD of the printer board may fix the problem. I have some if you want.
                    • ymmtech
                      • Jun 2009
                      • 190
                      Things to do before changing hard disk or install software.
                      The ir400,600 printer setup menu have built in feature to clear off problem that you mention. It is :
                      (1).Clear server.
                      (2).Restore factroy setting.
                      Normally apply the (1) will solve you problem.
                      If cannot solve, apply function(2).
                      If still not good after these 2 steps, then consider download software or chang hard disk.
                      Thanks.
