iR7095
  • Windpomp
    • Nov 2008
    • 9
    iR7095
    Need help on iR7095. Machine is giving message "suspended" and just freeze up when trying to make coppies. Did a firmware upgrade, did not help.
  • cdtw9803
    • Aug 2009
    • 51
    I always meet this message means "toner almost empty."
    1、restart the copier, give it a print job from PC or additional function.
    2、if it shows the message only when starting copying, there is a scan system problem.
    • davidj7
      • 1107
      what all additions do you have on the machine like finisher etc.Disconnect finisher etc and check
      a machine is only as good as your tech : source:screwtape ; the scary one
      • Windpomp
        • Nov 2008
        • 9
        Thanks fore response. Machine have booklet finisher installed.
        • cdtw9803
          • Aug 2009
          • 51
          read the user manual one more time
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Check to see if the finisher is out of staples.
            • andy21557
              Help Desk Technician
              • Jul 2009
              • 62
              agree with Oze
              the staple cartridge is prob not seated correctly ... take it out and try to copy you may need to clear the queue
              • SCREWTAPE
                • Aug 2025
                Also, I would check the rear and fixing feeder connectors for jammed paper. Is the fixing unit getting hot.
                • Kopyrtek
                  Copier Psychologist
                  • Jan 2007
                  • 407
                  Disconnect the finisher.If it passes a copy you know where to start.
                  • Windpomp
                    • Nov 2008
                    • 9
                    Thanks fore all the help. The service bulletins that i have also say that the "staple safety detection switch (front) may be faulty. I am going to the machine today and keep u posted. Thanks
                    • macuk
                      • May 2009
                      • 90
                      have had a piece of paper remaining in finisher after jam cause this to happen. Because of the way it communicates with the copier it does not show up a jam if machine has been switched off.
