iPRC1 E061
  • pga
    • Jul 2009
    • 67
    iPRC1 E061
    Dear all,
    After replaced new drum unit, m/c shown E061. I tried to clear DC-Con't,it works fine for while and happen again.
    I changed back old drum or another used drum, it still shown E061. Any ideas on it? all connectors are connected and fine.
  • SCREWTAPE
    • May 2025
    Did you rewire the primary corona? The drum life is 150k, the primary wire is 10k.
    There's not much you must do to remove the drum, check the wire and clean the grid or replace the primary.
    Check your dpot pontential in service mode as well.
