IRC 2380
  • jose dai
    • Dec 2008
    • 25
    IRC 2380
    Problems with scanner,while i scan the document appear on a small screen and and displays a message (performing ocr) and then error
  • victor_v
    • 71
    iRC2380
    Hi,
    What application use at scanning?
    Hardworking people are not present. Simply many it is boring to idle.
    • SCREWTAPE
      • Aug 2025
      Whats the DPI resolution setting your using?
      Its recommended 300 dpi or higher for OCR.
      • Iommanxman
        • Aug 2009
        • 180
        This sounds more like an application error. Not the built in OCR fuctionality of the MFP. What app are you scanning into or is this a send function from the copier?
