Canon IR3300 Error E000002-0000
  • jscraig
    • Jul 2025
    I'm new to this -- Canon IR3300 was just cleaned, serviced. Turn on power switch, error code E000002-0000 comes up; whole keypad is locked, so cannot get into service mode. I'm a user, not a service person, so any helpful hints (in simple English) would be appreciated; or clues I can pass on to my service person. Thanks
  • wilson
    • 27
    what you need to do is just resetting your machine.
    1. Press * 28 * on your machine in a quick move.
    2. Select copier
    3. Select Err.
    4. Select Clear then press O.K
    5. Turn your machine off for 1 minute and turn it on again.
    The error code will not be there anatmoreand your machine will be functioning well.
    • SCREWTAPE
      • Jul 2025
      I would call for service.
      You might need to replace
      a part.
      • jscraig
        I appreciate the quick response to my query -- but when you turn the machine on, the Canon logo appears in the window, and then goes to the error message -- the entire keypad is locked up -- can't activate "28" or additional functions, or anything. Any other ideas?
        • jscraig
          Whoops! Diligently tried your suggestion again, and it worked! Thanks for saving my life, and my business
          • ravibhati_4u
            Re: Canon IR3300 Error E000002-0000
            2. Select copier
            3. Select Err.
            thanks i solved this porblem
