RUI of Ir3300
  • jshirish
    • Jul 2025
    RUI of Ir3300
    Hi,
    I facing problem of RUI is not working. There are two machines and out of that one machine is accesable with RUI but the other is having problem.
    In the sytem setting RUI option is on. pl suggest the solution.
    Regards
  • SCREWTAPE
    • Jul 2025
    Firmware. Try loading the latest firmware. What other features does the other one have as far as printing,scanning?
    • jshirish
      Can you tell me how to load the firmware.Does it available on canon site for down loading.
      • CanonHPTech
        • Apr 2007
        • 235
        Yup, this is very common on this series. Sometimes it happens after a machine has been upgraded with new software. However, confirm that this is a model that can print, otherwise you will be wasting your time. But yes, the answer is to reinstall the software on the copier. The software is not a free download, but you may find someone here who will give it out or is hosting it on a free site. Be warned that it is not as easy as upgrading firmware on say a HP printer. A little bit difficult of a task that if not done correctly will down your machine. My suggestion would be to call a tech. Can be done in a short amount of time baring that you actually have a printer model.
        The glass maybe half full, but less is more...
        Printer + Fax + Copier = Jack Of Many Trades,
        but Master Of None
        Color Copier = Not A Color Printer
        InkJet MFP = Not A Fax Machine
        B/W Copier = Not A Press
        Finisher = Deal Closer (salesman, not accessory)
        Copier Tech = Admin's Stress Ball (Scapegoat)
