NP6035 Error E@C ????
  • Funnyfarm69
    • Jun 2008
    • 51
    Yes, you did read it correctly, I have an NP6035 which says in the display "ERROR E @ C switch off and on etc. Cannot clear in service mode. I have scratched a bald spot on me head with this one. Any ideas????
    sigpic MINES A PINT!
    • 23010
    I've worked on a lot of the NP-6035s and I've never seen a code like that. Could there be a bad area of the display screen corrupting the view of an "E005" or something like that?
    Does it attempt to initialize?
    Does the main power switch kick itself Off? If yes, it is most likely a scan lamp or heater lamp problem.
    Let us know what you discover. =^..^=
    • adel_nassan
      • May 2008
      • 21
      just try this
      enter to service mode and make ram initial
      tell us what happened!!!!
      • bineeshgeorge
        • Jul 2009
        • 107
        Hai,
        Is your scanning lamp turn ON continuously, from the time of machine turn ON ?
        Replace / Repair the power supply PCB, your problem will be solve ......... good luck...
        • Funnyfarm69
          • Jun 2008
          • 51
          RE: NP6035
          Hi all, at the moment I am just about to upgrade the customer with a new machine. As soon as I get the 6035 back I will try what you have suggested and post the results.
          Thanks for your time and help.
          • bineeshgeorge
            • Jul 2009
            • 107
            Hai Mr. Funnyfarm69,
            Just replace power supply PCB . E@C is related to power supply.................
