Make sure that you are loading the correct software into the machine.
5000 (Copier)
5000N (NETWORK)
If copier system software was loaded into a network machine, FORMAT and reload with network system software. If network system software was loaded into a stand alone machine, then FORMAT and reload copier system software.
hi.. please help me with this problems, my IR5000N cannot print from computers and the error code is E677-5803 (PDL no RIP hardware).. thanks ALL...
regards,
ben
Two possibility:
1. Machine type are not compatible between Boot ROM and System e.g BootROM of basic copy model is mounted on the system for PS/PCL model.
2.You need to have the RIP & Riser board for iR5000N.
