which one is best canon ir7200/ir8500
  • nissi143
    • Aug 2025
    i want to buy one canon recondition ir7200 or ir8500 which one is low maintanance low service problem
  • SCREWTAPE
    • Aug 2025
    There both the same. The only difference is speed. Maintanance will be the same.
    • davidj7
      • 1107
      depends on condition of machine you get.Most of the Re-con machines counter will be reset to lower.I have 8500's and 7200's both run well.
      a machine is only as good as your tech : source:screwtape ; the scary one
      • nissi143
        thank you for youre opinion
        • nivssluck
          • May 2008
          • 228
          iR8500 is better than iR7200 especially when it comes to ADF.
          • 20YRSEXP
            • Oct 2008
            • 281
            Like Screwtape said, they are the same. They use the same parts and service manuals. We have a 7200 with 8 million on it and it still does 200K between calls.
            Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
            • Blues Guy
              • Aug 2009
              • 216
              Prefer iR8500 due to the reliability. iR8500 engine is from GP605 where GP605 still working in good condition after so many years marketed in my country over here
              Cheerrsss.....
              • raveendra
                better u choose ir8500 bz for speed s good and working with gp605
                • karanoberai21
                  • May 2009
                  • 44
                  according to my area we have 7200 in more number than 8500. 8500 have tremendous jamming problem. while ir7200 is good to work in indian condition. still it depends on you.
                  good luck
                  • Canuck
                    Tech Specialist
                    • 1713
                    Same machines kinda...but dfferent document handlers...8500df J1 is like on a 600....excellent,no stream read glass on machine..... while the 7200df is like an ir5000 df...stream read glass on machine...good
