ir4570 faint at one end
  • mikeytech
    • Sep 2009
    • 6
    Hi all
    I have a ir4570 which goes faint at rear end sometimes when the right hand door is opened. Also opening and shutting the door cures the problem. Any ideas please.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    It sounds like a shutter issue...
    If you can try swapping the door with one from another machine...failing that you'll have to pull the shutter switch out and have a look at it..maybe bend it a little so that there's better contact.
    • prasathpr
      Door properly
      Door as properly use and maintain daily used in coconut oil.
      jobs
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Originally posted by mikeytech
        Hi all
        Look over your transfer/registration assembly for something strange. I have seen busted pivot/hinge on the bottom of a door, can't recall if it was 4570 or 3170, but one of those right doored beasties.
        • mikeytech
          • Sep 2009
          • 6
          Hi all thanks for replies
          I've changed the r/hand door and its cured the problem but can't see anything wrong with the door, will keep trying.
          • SCREWTAPE
            • Sep 2025
            Make sure that the springs under the ends of transfer roller are making contact properly.
