scan to mail and folder
  • prashant
    Hi;
    i am not able to do scan to mail and scan to folder configuration in irc3180 i have entered all the network setting but still im not able to do it it gives me an error of #801 which related to smtp server but i am able to ping that smtp from the machine and for scan to folder im not able to see any sharwe folder from the machine after giving all the proper permmissions does anybody have a some ideas about the same
  • binks24
    • Sep 2009
    • 14
    • SCREWTAPE
      Originally posted by prashant
      Hi;
      i am not able to do scan to mail and scan to folder configuration in irc3180 i have entered all the network setting but still im not able to do it it gives me an error of #801 which related to smtp server but i am able to ping that smtp from the machine and for scan to folder im not able to see any share folder from the machine after giving all the proper permmissions does anybody have a some ideas about the same
      You have entered all network configurations. Can you describe what you have done. Do have Anti virus software like, Norton,Mcafee. No offense, but are your computers network? Are they set up with a router,switch.
      • alex@wocltd.com
        • 430
        can you browse via smb to the folder on the copier?(as long as it in not $hidden share) if you can't browse that indicates that your gonna have a problem...
        • Iommanxman
          • Aug 2009
          • 180
          This is a very common problem. Things to try are. Use the SMTP server's ip address rather than the name in the network setup as sometimes it does not resolve the DNS naming convention properly. Also make sure that the user that you are using to scan has write access to the network share you are trying to scan to. Sometimes you have to enable the Exchange server to relay e-mails from the IP address. This is a setting within exchange in system manager (you may have to get the customer's IT to do this for you). You have to effectivly "white list" the IP address of the machine. After getting the basics like this covered then you need to start looking at user rights etc.
          • prashant
            Thank you, thank you for your valuable feedbak but my problem got resolved there is some aunthontication issue which was creating problem after giving proper aunthontication prblem got resolved.
            • Iommanxman
              • Aug 2009
              • 180
              Thats Great.
              • Kapten
                • 52
                Check this
                DNS If the dns isnt right then you have problem no 1
                Use mailserver ip instead of name. The physical name and the locical name is not alwas the same.
                Good luck
                • ninja copy
                  Copier repair
                  • Mar 2008
                  • 24
                  GOO""
                  Categories > Send Function
                  Electronics technician
