1320 jam code on a v2 finisher - has got me stumped finisher was bought in untested and presents this fault - have done everything AND then done everything again , cant see or think what it could be........
1320 on a v2 saddle finisher
Here's a case with that 1320
Disconnecting J202 on saddle controller cleared the jam. The machine became fully operational except for the saddle stitch unit.*Disconnecting J202 on an operational machine caused an error code of E5FA-8000.*This problem was duplicated by disconnecting connectors J202 and J203 on the saddle stitch controller. Solution : Replacing the saddle*stitch controller (FM2-5696-000)*resolved this issue. -
thanks screwtape - but have already replaced controller , though if i disconnect j202 machine will fire up and come to ready - but i was aready disconnecting j107 & j129 of the main controller.....
1320 is the most ambiguous code out there in the manual it says 'Paper exists within the transport path at power-on.'Comment
At which sensor is it jamming at? Have you check wire harnesses. Since its happening at power up, one of those sensors is not reseting.Comment
Try this.
February 27, 2008
Product : imageRUNNER 7086 / 7095 / 7105 Title : Jam code 1320 Problem :
Jam history shows jam code 1320 in the finisher.
Solution :
It has been found that the inlet sensor PS3 can cause 1320 jam code. Check the sensor in service mode COPIER>IO>SORTER>PO24> BIT13> 1 indicates paper present. Also make sure the entrance guide is not bent. PS3 is a reflector type of sensor. Part number for the sensor (WG8-5736-000). Canon USA, Inc. Systems & Technical Support Division1-800-528-2830sComment
thanks for all the input - I have'nt posted all I've done so far as I was hoping for a 'curveball' remedy - already checked i/o which made me change controller all bits(well most) were in true/on(1) state - see attached ,but this is with new controller - have used all 2 of the u.k u.fo's
swpped sensors & changed bits of loom......
attached is the i/o and the pdf of manual - all senosrs seem to be suggesting paper presentComment
