Hi i have changed the HDD to 40 Gb but the machines shows 8.7 Gb is the total hard disk Space how to Utilize the full HDD space?
Fully Ulilising the hard disk in IR8070
Manipulate SST tool
If you open the hd format file in sst and change the name of one of the disks to the name on your disk it could solve the problem.
Remark that you must have the exact amount of characters incl space till the ; .....
Then make a hd format again and reinstall the system again.
Im not shure that it would help.
8,7 GB is enough for the most printing so if the MC is working ok dont change anything.
Try to load a big pdf and se if it starts to print abort the job and be happy...
Nice Weekend..Comment
So in short, no, even if you have a way to format the drive to it's full capacity, the system software will never access it!"Once a King, always a King, but once a Knight is enough!"
even if you 'clone' the drive the partion(s) should stay the same otherwise it won't work - that why canon started sending out 80gb hdd clipped to 40Comment
My two cents worth...
The real reason Canon has gone to a 80gig drive is simple,, availability. If you had been purchasing drives outside Canon channels, and buying the same drives that are in the copiers, what you will have found out, is that those drives are no longer available. Those models simple outlived the manuafacturers run. Those drives don't even use the 40 gig you mentioned. Most of these models would run on 20 gig.
I had some 160 gig drives running in our 3.5" models. The excess space was not utilyzed, but the $60 price tag for a 160g drive was better than the $300 for a Canon provided drive."Once a King, always a King, but once a Knight is enough!"
I found it...
http://www.copytechnet.com/forums/attachments/canon/1729d1249021118-ir2270-format-hdd-sst_-_hdd_not_found.pdf
Oze gets the credit for this..."Once a King, always a King, but once a Knight is enough!"
Sorry abkonnet, I forgot that the 8070 was in the series that started to encrypt the format file. The 8500 did not. I do not know how to crack open that formatter. Only advice I have is to find same hard drive that is in the copier, or the one from the hard drive list I created, HTS541640J9AT00"Once a King, always a King, but once a Knight is enough!"
