3220 printing problem
  • sgcopiertech
    • May 2025
    3220 problem when printing more than 1 page
    first page will come out but the second one would
    not be processed. machines shows "waiting to print"
    I did a firmware update but still have the same problem.
    any suggestions?
  • SCREWTAPE
    • May 2025
    any suggestions?
    Problem could be the file.
    What file format is it?
    • sgcopiertech
      previous problems from other machines was due to the file itself (mostly email attachments)
      but i think this one is a bit different.
      i've tried, txt, pdf, .doc, .xls and even jpg
      as long as it has more than 1 page.
      it will print out the first page, and then the next is stuck with the "waiting to print"
      I tried to cancel the print in the system monitor > print > cancel
      but it will then get stuck with "cancelling"
      • SCREWTAPE
        • May 2025
        Is this a isolated problem or is it happening with other computers.
        Do they have a imagepass?
        • sgcopiertech
          I've tried printing into another printer (iR3300) and it just works fine and I've also reinstalled the printer driver (canon 3220 PCL5c)
          how do i check if it has an imagepass? service mode>copier> version?
          • SCREWTAPE
            • May 2025
            The imagepass hangs at the rear part of the machine.
            If there is a imagepass you will also see a printer tab
            op panel.
            • sgcopiertech
              i see, I don't see anything hanging from the rear of the machine, and also there is no printer tab on the panel. so i guess this one got no imagepass.
              so far, I have tried to clear MMi > format hdd> reinstall system software. change computer.
              but still same problem.
              • pengtech
                • 41
                maybe u can try changing the RAM.
                • SCREWTAPE
                  • May 2025
                  As I back track this thread, we singled out the fact that you don't have ImagePass. But i notice something you said that you tried printing into another printer (iR3300) and it just works fine and I've also reinstalled the printer driver (canon 3220 PCL5c) Have tried using a UFRII driver.
                  Also as pengtech mention, maybe you can reseat and or replace the two Dimms(512mb), Dimms(256mb).
