Hi, i'm desesperate, i can'tr find how to condifure the network card, in the display don't appear nothing concerning to it, some one has a manual to do it. thanks...
Setup network card in IR600
There is a print/if key on the control panel. Once you go into it, just run setup. Justmanuals.com should have the manuals you need. -
It is not easy for you to enter the setup mode if no body tell.
Restart machine by switch off and on main power.
Press the P I button, wait for the "Run setup ?" message. (This screen appear 20 seconds after power on)
Press "Y" within 5 seconds.
Wait another 2 minutes, you should be in set up mode.
You may need to key in password if the previous owner set password.Comment
print a test page and see if IP is already configured .If it is then open internet explorer and go to that IP address. you can also use command workstation 3.0 from www.xerox.com website.a machine is only as good as your tech : source:screwtape ; the scary oneComment
