Setup network card in IR600
  • yuen
    Hi, i'm desesperate, i can'tr find how to condifure the network card, in the display don't appear nothing concerning to it, some one has a manual to do it. thanks...
  • SCREWTAPE
    There is a print/if key on the control panel. Once you go into it, just run setup. Justmanuals.com should have the manuals you need.
    • ymmtech
      • Jun 2009
      • 190
      It is not easy for you to enter the setup mode if no body tell.
      Restart machine by switch off and on main power.
      Press the P I button, wait for the "Run setup ?" message. (This screen appear 20 seconds after power on)
      Press "Y" within 5 seconds.
      Wait another 2 minutes, you should be in set up mode.
      You may need to key in password if the previous owner set password.
      • SCREWTAPE
        If you run into this, you may need to reinstall firmware. This is why i suggest getting some sort of manual regarding the procedures. These printer boards require more attention when setting up.
        • ymmtech
          • Jun 2009
          • 190
          But can scan for password.
          • SCREWTAPE
            What do you mean?
            I remember, in order to reset password reloading firmware was the only option.
            • ymmtech
              • Jun 2009
              • 190
              Shhhhhh...........using non standard way.
              • SCREWTAPE
                • davidj7
                  • 1107
                  print a test page and see if IP is already configured .If it is then open internet explorer and go to that IP address. you can also use command workstation 3.0 from www.xerox.com website.
