e005 error code on ir5000
  • jiongpao
    • May 2009
    • 413
    I encounter twice of this problem before for e005 error, we suppose to change web roller and clear the error tats it. But even after we changed the web roller and clear the error but it still appearing e005. it went normally just after i changed the DC controller PCB.
    Is there any way or chance to fix the existing DC controller PCB beside changing a new one? Did anyone encounter this problem before? It happen to me twice.
  • SCREWTAPE
    Not really that I know of unless you know how to fix circuit boards.
    • andy21557
      Help Desk Technician
      • Jul 2009
      • 62
      e005
      have you cleared the counters ?
      service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB>
      • sayednabil
        • Sep 2009
        • 72
        IR200 Code E100
        well i have open the laser unit for cleaning purpose after putting back the unit i am getting the code i have change the ccd cable after also i am getting the code E100 is there any solution..Help Needed indeed. thanks
        • bojans
          • 1313
          You should open laser unit and check is every mirror on its place (maybe you moved some of them, when cleaning), and check shutter which opens/close laser. (it's small plastic that opens laser when you close/open front cover/left cover)
          I had this problem several times
          Good luck
          • andy21557
            • Jul 2009
            • 62
            gees
            Im confused ... too many different models in this thread
            • Kapten
              • 52
              Quite expensive way
              Its quite expensive to change the dc controller when clearing web counter is the right way..
              In most cases...
              • waffu22
                • Jun 2009
                • 95
                [quote=jiongpao;100795]I encounter twice of this problem before for e005 error, we suppose to change web roller and clear the error tats it. But even after we changed the web roller and clear the error but it still appearing e005.
                Just try to change the sensor...
                • jiongpao
                  • May 2009
                  • 413
                  andy21557 - yes cleared the counter but nothing changed still appearing e005
                  waffu22 - will try on changing the sensor and will coming back here
                  But can anyone look for me the part number of the web roller sensor that making e005 code? sorry im leak of ir5000 part catalog
                  • jiongpao
                    • May 2009
                    • 413
                    for the ir5000, ir7200, ir105 drums that got holes or scratch causing the printout in dirty page with dots, is there anyway to fix it or can ya guys fix it beside changing new drums?
                    • waffu22
                      • Jun 2009
                      • 95
                      Change a new drum.
                      • jiongpao
                        • May 2009
                        • 413
                        i found a webie that show theres a way to fix several parts like drums perhaps ya guys may have a look does it really work out ?
                        Rotby, Inc. - Drum Coating System
