Ir 4570 copies through out adf lgl size cannot come clearly?????
  • SESHU
    • 163
    HI FRNDS.....
    THIS PROBLEM IS SAID TO ONLY FOR ADF.
    MY IR 4570 MECHINE A4 COPIES ARE IS COMING VERY WELL IN TO ADF OR PLATTERN GLASS.. IN PLATERN GLASS ALL COPIES PRINTED VERY CLEARLY. SO PROBLEM IS....... WHEN I MAKE COPIES THROUGH OUT THE ADF . A4 SIZE PAPERS/COPIES PRINTED CLEARLY. THAT'S NOT PROBLEM.
    O.K .
    BUT WHEN I MAKE COPIES THROUGH ADF LEGAL, A4 R and A3 SIZE PAPERS SCANNED SUCCESSFULLY BUT COPY PRINOUT ITS COMES FIRST OFF PAGE WHITE..DOWN THE PAGE OFF COPY PRINTED.. THAT MEANS PRINT OUT IS MATTER PRINTED START AT DOWN OFF PAGE. CANNOT PRINT COMPLEATLY. FIRST OFF PAGE WHITE PAGE.. DOWN OFF START THE PRINT.THAT IS PRINT OFF ONLY.
    HOW IT IS?????
    A4 SIZE PAPERS VERY WELL TO PRINTOUT/COPIES ITS' COME VERY CLEARLY .
    BUT PROBLEM ANY A4 R AND LEGAL SIZE AND A3 PAPERS PAPERS SCANNED SUCCESFULLY.WHEN COPY PRINOUT ITS COME OFF PAGE.
    PRINT CANNOT START THE UP EDGE. PRINT START 'S MIDDILE OF THE PAGE EDGE.
    CAN U SOLVE ANY BODY THESE PROBLEM.
  • Kapten
    • 52
    Im not shure
    I dont know if i has understand your problem.
    But the first to check is the sensors in the adf tray.
    Change the photointeruptor with each other and se for the result.
    One flag is possible displaced..
    It could be the width sensor that had came out of place or needs an adjustment in sm / mode feeder
    The cable to the green lamp could be defect
    Good luck
    • SESHU
      • 163
      But a4 copies adjusted hight and width very clearly..
      Only lgl and a4r papers copies printing starting middle of the paper..
      How can i adjust lgl,a4 r and a3 size sensor settings...
      • smiley
        • Aug 2008
        • 615
        hi you have to set the feeder to A4.go to service mode then go feeder function then press try-A4 then ok then adjust feeder guid toA4R and press try-A4R then ok then do it in all paper size follws.gud luck
        there is no glory without sacrifice
        • SESHU
          • 163
          hi..
          thank you for reply...
          how can i check A4 R AND LGL..
          IN FEEDER FUNCTION DISPLAYS. TRY A4,TRY A5R,TRY LTR,TRY LTR R ONLY ...
          THERE IS NO DIAPLAY TRY A4 R AND LGL AND A3 ...
          HOW CAN I ADJUST AND HOW CAN I SET IN THESE OPTIONS FOR ABOUT MY PROBLEM...
          MY PROBLEM IS PRINTING STARTED A4 R AND LGL... ANY (WITH OUT A4) MIDDLE PAGE OF THE COPY PAPER..
          HALF PAGE WHITE AND HALF PAGE COPY PRINTED..
          GIVE ME REPLY FRND...
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            let me take a stab at it...
            If I understand your problem, the copies are way down on the page cutting off your image? ( I don't work with A sized paper in the States, so I don't, know offhand which sizes are comparable to which sizes I deal with) If the pages are long, like legal, make sure the tray sensors are being activated. Curled paper will not hold them down, and then the copier makes wrong decisions for you. Try your long documents with the flags taped down just for a test, to see if you get good results. If you do, then you have a problem with curled originals.
            • SESHU
              • 163
              I am checking all type of orizinal sizes. A4 copies are comes its clearly..
              lgl size and a4r and a3. i think these paper sensors cannot activate.
              I can checking lgl size and a4 r originals .these are checking somany types of way to checking. But cannot comming. Half paper white middle of the paper printing started.
              I konow curled originals cannot come priniting.
              And i can set it to originals where is flags dispalyed. That'sway iam following.
              But no results..
              • mrfixit51
                • Oct 2008
                • 1975
                But no results..
                Lets stick with legal here for the sake of easy understanding... If you put a legal sized document on the document glass and copy it, is your image correct? Now, if you tape down the two long paper sensor flags on the document feeder entry tray, and feed your legal sized document thru the doc feeder, is your image correct?
                Are the dials set correctly in the paper drawers to properly signal what paper is in each drawer?
                • costd
                  • Jan 2008
                  • 409
                  I also do not work with the A4/A3 settings - but it seems a little strange that you can mix the LGL in with the A3. LGL is inches and A3 is metric (I think). Make sure the drawer dial and US/Metric are properly set.
                  • sgcopiertech
                    sensor P13
                    check your paper size identification signal 2 (LENG2S) JS-2
                    • SCREWTAPE
                      • Aug 2025
                      How many trays do you have? "Let's just say you have two"
                      When you go into paper select what sizes do you see?
                      A4,A4-RA3,B4,LTR,LTR-R,LGL,11x17. What do you see.. Have you checked the inch size switch on the side of the cassette next to th blue dial, you A/B and then inch. There has to be a wrong setting some where.
                      • SESHU
                        • 163
                        i have 4 cassetes. 1. A4, 2.A4R , 3.LGL, 4.A3.
                        YOU KNOW MY MECHINE WORKING ADF WHEN IAM TAKING NEW ONE. ALL SIZES COORECTLY PRINTED. NOW A DAYS IAM USING MOSTLY A4 ONLY. BUT RECENTLY I HAVE TRY TO USE A LGL COPIES . BUT PRINT ITS COME MIIDLE OF PAGE.
                        ON THE GLASS IS CORRECLTY PRINTED. WHEN IAM MAKE A COPY THROUGH ADF.
                        ONLY LGL AND A4 R PRINTING STARTING ANY TRAY OR BY PASS TRAY ALSO MIDDILE OF PAGE PRINTING.
                        WHAT TO DO??????????
                        • mrfixit51
                          • Oct 2008
                          • 1975
                          One more try...
                          When you are making copies thru the ADF, are you selecting the paper to be copied onto, or is the selection set to AUTO?
                          Try it on AUTO,, if it feeds shorter paper than your original, then the problem lies in your ADF, because it cannot sense the paper length. Check your entry tray length sensors,, they both should be activated by legal paper or longer.
                          • SCREWTAPE
                            • Aug 2025
                            Did you try this yet?
                            It sounds like you might have
                            to initialize your ADF tray settings.
                            • SESHU
                              • 163
                              How can i try this method ???
                              HI..
                              HOW CAN I TRY THIS METHOD????????
                              HOW CAN I ADJUST AND HOW CAN I SET IN THESE OPTIONS WHAT YOU SAID AND ABOUT MY PROBLEM...
                              AND HOW CAN I INTIALIZE ADF SETTINGS?????????
