Help Setting a canon 3220 w/ imagepass c1
  • paginitas2000
    • Aug 2025
    Hi
    I just get a canon c3220 with a imagepass c1, I was unable to connect it to my local network, How I can access a setup process on the imagepass c1, there is a special software to do that? Can I do that from the copier UI?
    I ping the imagepass using an IP from the copier report, but it is unaccessible, in other words, I can't do anything.
    Please if somebody can help it will be really appreciated. Thanks
  • hari_4848
    • Jul 2008
    • 91
    C1 firy setup steps
    Hi,
    You need to connect the C1 fiery using a video cable(looks similar to your scanner cable) and also a crosscable or patch cable(watever u call it ).
    Connect one end of the video cable to the C1 and other end to the machine , below the scanner connection.
    Also, connect the crosscable's one end to the machine,in the nework port and other to the fiery, here u c 2 network ports, connect it to the port which doesnt have a network symbol(3 comps attached) near it.
    Then, switch on both the machine and the fiery.
    If the connetion is setup well, u can see the procssing data light blinking as soon as u on the machine and the C1fiery.
    Then, click on the printer tab on the control panel and setup the network connection.
    U need to have 3200 print drivers to take a print out .
    Thanks.
    • pga
      • Jul 2009
      • 67
      u need to go svc mode > option> interface> change '0' to '3'. off and on machine and server. from panel,u will able to see 'printer' and from there,u go to 'setup'. Default password is Fiery.1
      • paginitas2000
        thanks hary 4848
        Everythinhg is setup as you suggest, my impresion is that the fiery is not able on the copier 3220.
        thanks again
        • paginitas2000
          thank you pga
          i did what you suggest, interface is set to 3
          Thabks again
