Irc 3200 supplys
  • pontiac
    • 420
    Irc 3200 supplys
    Does anyone have other sources for new imaging units to purchase these guys are expensive, even a supplier for rebuilding these units would be sweet. Thanks everyone.
  • pengtech
    • 41
    Yes i agreed that the drum unit is costly, But using rebuild unit or toner as you said can reduce the cost but the quality you get maybe lousy. so you need to visit your customer very frequently to settle the problem. Worst case your customer loose confident in you. Since you want to play this model you have to bear the costs. So you must judge which one is important.
    • Oze
      Ricoh Fanboy
      • 1663
      Well said Peng...couldn't agree more.
      • pontiac
        • 420
        Thanks for replys guys. Staying with OEM
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Try a different vendor.
          • pengtech
            • 41
            If you insist on the OEM, it is advisable that you use the same vendor/supplier especially the toner.
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              I really dislike using any generic color toner but at the insistance of a customer who wanted to reduce costs we have been using the Katun IR C3200/3220 toner. More than 100,000 copies made with no problems whatsoever.
