IR 3100C flutes and crumples paper
  • copyhome
    Can you help me with my Problem?
    This Canon IR 3100C flutes and crumples paper, did you ever had this problem before and what is the remedy ?
    Below there is a foto of what i mean.
    The owner of the copyshop is my brother, but he is to impatient to solve this problem, so i decided to help him.
    We had several Problems with the IR 3100C before.
    First Poblem was a E000020-0081, i cleaned the Paper Sensor after finding the solution in internet-forums.
    Then later one customer brought us some thin overhead slide to copy, that was a failure in my opinion. The overhead transparency melted in the heating roller and plugged the copier.
    It was a hard work to dissassemble the copier and cleaning it from the foil
    I think the crumpled paper now results of eventually damaged heated rollers or do you have another idea ?
    We also have not enough money to take a technician
    edit: some typo...
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Probably you need to replace fixing unit but not without technician!
    Time life for roller-100 000
    fixing unit-200 000
    • Kapten
      • 52
      If you
      If you are trying to change the fixing rollers 2 pcs dont forget the eject rollers to.
      Or the whole assy and get happy in 15 minutes...
      • copyhome
        • Brian8506
          • 1666
          That sounds fair. I would change the whole unit. Too many things can go wrong diassembling those but it's your decision and your time.
          • Gerhard
            • Oct 2009
            • 99
            I agree The unit gets deformed bent and buckled. Replace the unit and you wont have any problems for 100 000 prints.
            Regards
            sigpic
            Life is a Journey enjoy the ride !!!
            • spotlifter
              • Mar 2008
              • 65
              By any chances, can u tell us whats the latest firmware/updates version to resolve this issues? I wanna go check mine.
              Originally posted by marc.lucas
              One point to mention that there is one issue where if the copier is left on or on stanby for hours at a time the lower roller gets a flat spot, this causes jams & smudging etc. Canon brought out a software update to address this issue, so even with a new fixing unit the problem could reoccur if this update has not been done.
              sigpic
              • zoraldinho
                • Mar 2008
                • 5018
                your counter is 209 000? Only way is replace fixing assy.Cost about 600 eur.
