Meter reading reporting
  • cweber0531
    • 71
    Have a customer that has multiple users in one office and they want to bill separately on department ID's. What would be the easiest way to pull usage reports? Through the interface?
  • 10871087
    • Jan 2005
    • 1143
    Well I guess it could depend on a few different factors, none of which you gave us in your question. What equipment do they have, what volume, type of business, how many users...
    • bnmand
      • Sep 2008
      • 383
      I agree.
      Depending on the hardware you have installed you have multiple options. e.g. with 3300s if networked you can view DepID Totals through the RUI web interface, not just using the copier interface to either view it on the copier or print it off.
      • cweber0531
        • 71
        Machines are IR5570 and IR3045. Have about 15 users and want to be able to pull usage reports on a monthly basis.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5000
          The easiest way is to sell uniflow.
          • SCREWTAPE
            • May 2025
            Dept Id is fine.
