Cannon CLC5100 E061-0214
  • adune
    • Aug 2025
    Does anyone know how I can resolve this error, the machine was moved to me, now has this code:
    E061-0214
    Primary Charging assembly faulty
  • SCREWTAPE
    • Aug 2025
    E061-0214
    The sub code 0214 is for magenta.
    Could be the primary or the drum for magenta.
    • adune
      CLC 5100 new error E061-0416
      original error was E061-0214
      any ideas
      • SCREWTAPE
        • Aug 2025
        any ideas
        As I said the E-Code Is 61, but the 61 could be anything in the image formation area of the machine. The sub code points you to magenta. The 02 in the sub-code refers to magenta. Had it been cyan then it would be E061-0314. If your not a tech, then i would suggest you have one look at your problem.
