white copy in IR2200
  • adel_nassan
    • May 2008
    • 21
    Hi every body
    Am Adel from Egypt
    i have a white copy in IR2200
    i change the drum unit , toner tank , and DC board
    i chick the bias of primary and devolper tank are ok
    ther is no image on drum
    please help me
    please write replay in simple english because my english is bad
    thanks
    bye
  • copicatt
    • Nov 2008
    • 366
    Make sure and check all your door specs. I have seen them change "out of the blue" due to a surge or something. This will cause a blank copy and none of the things you have done would have made a difference....
    • SCREWTAPE
      • Aug 2025
      Has they been any error codes in the past with regards to the laser.
      Is this machine a printer or are you making copies off the glass?
      • davidj7
        • 1107
        go to factory settings mode and do am all ram clear, it should bring something if its a settings issue
        a machine is only as good as your tech : source:screwtape ; the scary one
        • mata
          • Mar 2009
          • 46
          Check if gear on machine that rotates the drum is ok. I have a couple of these that broke to pieces. No drum rotation-no copy.
          • montana
            • Aug 2008
            • 392
            hi adel you are welcome......
            to troubleshoot this malfunction you have to check the printer by test print or print report to be sure if the error in printer unit or with the scanner unit.....try to replace the transfer roller...also check the drum unit driving gears check switces&contacts
            i hope you goooooood luck....thanks for all.
            • adel_nassan
              • May 2008
              • 21
              thanks for your support
              now there are a copy but it's bad ( like bad transfeer )
              it's light
              but not all paper light , i mean there are apart is light and other is more dark
              some times there are error code E0064-00002
              i check that :
              drum drive is ok
              all door is ok
              i print laser test but it's not good also
              i change laser unit ( no differance )
              i check the bias conection is ok
              what now????/
              please help me
              thanks
              • SCREWTAPE
                • Aug 2025
                Try replacing the HVT.
                • davidj7
                  • 1107
                  what did you do immediately before, when you got the bad transfer copy
                  • pengtech
                    • 41
                    Check whether the paper is damp or not. Also check the developer engagement system ( the engagement bar ) sometimes the plastic catch behind the bar came off causing different pressure in locking the developer. Change the composite power supply and the transfer unit.
                    • creppy
                      • Nov 2009
                      • 28
                      Originally posted by adel_nassan
                      Hi every body
                      Am Adel from Egypt
                      please help me
                      thanks
                      bye
                      chek potensial control, potensial sensor, scan lamp, laser unit, and reader controler
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        Dev bias...or as simple as not locking the dev back into place after fitting a drum...(a trainee Tech did that with me on a call today)
                        • Tim C
                          • 167
                          Are you using an OEM Drum... I have had issues with genaric drum units for this machine...They look ok but they fail quite often. do you still have the old drum. put it back in and try it.
                          • madu132
                            • Dec 2008
                            • 65
                            do you use original toner?
                            if not maybe you mis use with toner for ir 7200/8500.
                            It happens once with me.
                            try to clean the developing and then refill with fresh toner
