Hello All!
I'm in need of some help with a Canon Ir5570 networking issue that I'm having. Our office got a new-used Canon Ir5570 and I'm in the process of getting it to work with our network. We have a small office with Hub switches and one T1 router etc.. Peer to peer XP environment etc..
I'm reading thru the network Guide setting up this copier to get it to talk. I'm following the step by step procedures and I'm not getting the machine to talk to network. Plus the "Check TCP/IP" notification keeps poping up. If I go to try to make changes in the Control panel, Network settings area, I'm not getting all the displayed function buttons to change IP address etc.. that the guide is stating or showing. The Hub the copier is connected to is showing it's there and talking. But I'm missing these menu areas to make the changes the Guide is talking about. I've turned it on, when I go into the I go into Tcp/IP settings I do not gett the menu buttons to change the IP stuff or config stuff etc.. Thanks for your help in anyway!
