Canon IR5570 Networking Problems!
  • JWebber
    Hello All!
    I'm in need of some help with a Canon Ir5570 networking issue that I'm having. Our office got a new-used Canon Ir5570 and I'm in the process of getting it to work with our network. We have a small office with Hub switches and one T1 router etc.. Peer to peer XP environment etc..
    I'm reading thru the network Guide setting up this copier to get it to talk. I'm following the step by step procedures and I'm not getting the machine to talk to network. Plus the "Check TCP/IP" notification keeps poping up. If I go to try to make changes in the Control panel, Network settings area, I'm not getting all the displayed function buttons to change IP address etc.. that the guide is stating or showing. The Hub the copier is connected to is showing it's there and talking. But I'm missing these menu areas to make the changes the Guide is talking about. I've turned it on, when I go into the I go into Tcp/IP settings I do not gett the menu buttons to change the IP stuff or config stuff etc.. Thanks for your help in anyway!
  • JWebber
    I get this screen menu like this 3 and 4 but once I go into TCP/IP settings I do not get the 5 and 6 menu.
    • SCREWTAPE
      Do you have a fiery?
      Its a print controller.
      • JWebber
        Originally posted by SCREWTAPE
        Did you turn on the first option above. Change setting display network connection confirm.
        Yes that is ON and powered her down and restart it up. When I turn it on and reboot etc. That s when I get the TCP/IP check display on main menu screen. I have followed the book to the tee, Just not getting the 5 and 6 screen menu options. Instead I get
        Use PASV Mode For FTP (Button)
        Certificate Settings (Button)
        Proxy Settings (Button)
        IP Range Settings (Button)
        Receiving MAC Adress Settings (Button)
        Looks nothing like 5 and 6 screen shot nor option like that.
        • JWebber
          Fiery?? Fill me in!
          • SCREWTAPE
            Originally posted by JWebber
            Fiery?? Fill me in!
            Alright you must go into service mode and change the interface option back to 0.
            It seems that there was a fiery hooked to this imagerunner.
            Hit additional functions and the 2&8 then additional functions again.
            Go into copier-option-int-img-con. Turn back the value to 0,
            Then reboot.
            Let's keep in mind that you might not have a printer kit install.
            Try this and post back.
            • JWebber
              Then reboot.
              Ok! I'll give it a try.
              • JWebber
                Hey that worked! I rebooted and Now I'm seeing the menu buttons etc.. Thanks a lot for your knowledge on this issue. You are the man! I was going crazy trying to find the issue. I'm now going to be around this forum for a long time. Thanks soooooooooooo much! I got people breathing down my neck at this time... Cheers!
                • SCREWTAPE
                  No problem.
                  But your not outta the woods yet until you print out that test page.
                  • JWebber
                    No problem.
                    I'm out of the woods, I just installed the printer driver on a remote computer and got to print out. Thanks once again! Also got the remote user interface to work via web browser page window. Thanks!
                    • SCREWTAPE
                      You got it.
