Toner being dumped on cleaning blade stay (3200)
  • dagoof
    Still learning...
    • 220
    I posted about this a couple of weeks ago but still having problems with my 3200 dumping a load of toner on the cleaning blade stay.
    It was suggested on my last thread I check that the gear that drives the blade was ok (it is). The other suggestion was to change the drums - 2 of them were only 12% used - I just replaced the other 2 to be sure but I've still got the problem, so don't think it can be that.
    I've attached a pic of the problem - the only strange thing I encountered was a bit of the black foam was loose/torn off on the right hand side of the stay.
    Anyone got any ideas on this?
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Check the drive for the cleaning unit coil.
    • waffu22
      • Jun 2009
      • 95
      maybe u did not put properly the cleaning blade.
      • dagoof
        Still learning...
        • 220
        Thanks for the replies.
        Kopyrtek - I checked and the coil turns ok with the gear, if that's what you mean.
        Waffu - yes, it was seated correctly, I've had it in and out numerous times and it's still doing it. If it makes any difference, it was a new blade assembly I put in just before this started happening.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Was it a new blade, or the entire asm? Since you have alluded to a timeline, that points to the blade installation, I would advise replacing the entire blade assembly, and make sure that it has drum lube on the edge. A possible "dry spot" on blade could set up some vibration, blowing the spent toner out of the asm in that area.
          • dagoof
            Still learning...
            • 220
            Hi Mr Fix,
            It was the entire asm - I'm just thinking though, I don't think it came with any lube, do they have to be lubed from new? that could well be the problem!
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              There is a new style mylar for that. It's a little stiffer and blue in color. I had the same problem in a cir5180 dumping toner on copies as it passed under.
              Part #FB6-3118-000
              • dagoof
                Still learning...
                • 220
                Thanks DLP - is that the thin rubber sheet below the blade asm? I'd had to vacuum the excess toner off the asm and thought this might've been drawn out of position.
                • D_L_P
                  Self Employed
                  • Oct 2009
                  • 1196
                  I think it's the same, this is the mylar on the waste toner coil assy. It's just below the ITB belt cleaning blade assy and just 1 screw to remove it.
                  Sounds like the same thing I had, a big pile of toner on that rail. I vacuumed it and it came back. I replaced that mylar and havn't seen it again. GL
                  • dagoof
                    Still learning...
                    • 220
                    Thanks DLP, will give that a whirl!
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      Good info...
                      Thanks D_L_P
