ir7200 e111
  • jiongpao
    • May 2009
    • 413
    ir7200 e111
    Hi pro tech,
    According to the SM e111 should be a fm14 scanner unit cooling fan faulty. I changed the fm14 colling fan together with DC Controller PCB the problem still exist. Is it something to do with relay board?
  • SCREWTAPE
    • Jul 2025
    Originally posted by jiongpao
    Hi pro tech,
    What's up Jiongpao,
    The symptom can also occur because the cable of the right deck pickup clutch (CL10) could be short-circuited So, visually inspect the cable for abnormality.
    Right Deck Pickup Clutch: FH7-5826
    • jiongpao
      • May 2009
      • 413
      Just wasting few hours for this .. thiss .. code. Will try on that part number and get back to here soon.
      • 20YRSEXP
        • Oct 2008
        • 281
        Keep in mind the clutch will cause this because of the short in the 24V system. Door safety switches can also cause similar issues. Shorts can be tough, good luck with it.
        Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
        • 20YRSEXP
          • Oct 2008
          • 281
          I would also try unplugging the deck and see if the code goes away. If it isn't the side deck try unplugging one connector at a time on the DC controller. If the code goes away track down where those loads go.
          • jiongpao
            • May 2009
            • 413
            Thanks all, i changes the clutch and it goes normally
            • SCREWTAPE
              • Jul 2025
              Glad to hear that.
