iR3300 fax
  • sgcopiertech
    • May 2025
    iR3300 fax
    fax always show "recieving..."
    tried to clear using service mode > fax > clear > all
    still same problem. is this a setting issue or a faulty hardware issue?
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    There might be a fax job stuck on the HDD. In service mode go Copier>function>system>CHK-TYPE.
    Select 1, hit ok.
    Select HD-CLEAR and ok.
    Go back to CHK-TYPE and select 2, hit ok.
    Reboot. Also, leave the phone line disconnected when your doing all this. When you get a ready screen then connect the phone line.
    • sgcopiertech
      Select 1, hit ok.
      thanks for the reply.
      sorry for not being to clear about the problem.let me explain a bit more:
      I'm using a single machine to test 1 batch of purchased fax board.
      some boards are tested ok, some boards have this "recieving error"
      so I don't think the problem would be from the machine hdd.
      2nd the error "recieving" would come even if the phone line is not attached.
      any other ideas?
