iR 5000i Display prolbem
  • mata
    • Mar 2009
    • 46
    Is there any way to calibrate touch screen. It dislocates buttons a litlle at bottom of the screen and grows to the top sa I can't even walk thru service menu. Limited only to DISPLAY window.
    tnx
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    tnx
    Service Mode>Copier>Function>Panel>Touchkey
    It presents 9 targets to "bullseye" the panel back to usability,,, I had to do this a couple of months back to one of mine. I had to use a stylus initially as the calibration was off considerably...
    • mata
      • Mar 2009
      • 46
      I can't touch FUNCTION button...
      • mrfixit51
        • Oct 2008
        • 1975
        Even with a stylus pen,, at the top of the display? If not, you will need a replacement operators panel,, if you want to be able to utilyze service mode. There is no other way to get into the Touchkey adjustment except thru the process I outlined for you...
        • Brian8506
          • 1665
          I've had the same problem. If it's off by too much you need to replace the lcd.
