IRC3100n Error code# E000020-0081
+ More Options
Posts
  • Caldo
    • 69
    Hi,
    Got an error on one of my machine, error code#E000020-0081, Tried cleaning the patch image reading sensor window and re-inserted developer and drum several times to fit in properly and still i get this message appearing on the screen.
    Does it have to do with the toner cartridges? or any other explananation?
    Rgds
    Caldo
  • SCREWTAPE
    • Jun 2025
    Originally posted by Caldo
    Hi,
    Rgds
    Caldo
    Try replacing the drum.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Drum at end of life
      • Caldo
        • 69
        Thanks for the reply, have tried replacing with a new drum still got the error message. Had the one old drum replaced and still got the error meassge displayed again.
        Could this be something to do with Toner?
        Rgds
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          By patch sensor, are you refering to the one just to the 10 o'clock position on the drum area? Some folks get confused by the sensor with the shutter to the left of the rotary. Have you cleaned it with compressed air? You seem to have ruled out the drum. Are the copies clean? I have seen drums suck their clean blades in and leave dirty surface on the drum. If you have and you are still having problems, you may want to replace that sensor to see if that gives your problem relief...
          • Caldo
            • 69
            Hi guys,
            Thanks for all the help, really did help me solve my problem.... had to replace the sensor and cleared away the error code.
            Cheers
            Caldo
            • SCREWTAPE
              • Jun 2025
              Thanks for posting back. Happy to hear that your problem is solved.
