ir3045
  • zefixe
    • Sep 2025
    ir3045
    hi, i have problems with the fixing film of ir3045.
    I've replaced many fixing films. please help me
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Is it an image problem?...or toner rubbing off the page?
    If you've changed the film the you may need to fit a new pressure roller or look at the toner being used.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      More info about your actual problem please...
      My best advice is don't do too little. Replace fixing film ASSEMBLY, not just the film. Replace the pressure roller and the bushings,, now you have basically a new fuser. If you have at least 200% on the clean roller, replace that as well.
      • MrB
        • Nov 2009
        • 147
        IF you ever do just refilm the fixing asm
        Also remember to replace the cleaning roller
        (No point in just doing the film and not the roller, neve get a good long life on a new one with a dirty cleaning roller)
        Also might be worth running it without the roller
        • davidj7
          • 1107
          how many copies do you get between films? Are you Genuine Canon films or compatable?
          a machine is only as good as your tech : source:screwtape ; the scary one
          • Monsoon
            • Nov 2009
            • 16
            Fixing film assembly is a must, don't just replace the fixing 'sleeve'. I'm from england and generally get 200-250k out of a fuser which I rebuild.
            When I rebuild I replace fixing film, pressure roller, cleaning bar and must importantly bushings and bearings of pressure rollers (this I have noticed stops the E007 occuring) as the pressure roller moves freely.
            Monsoon
