hello all can you healpe me please ..can any technician informed how l can inisialized the ir 2016 ..l'm waiting .
hello technician
sgcopiertech
ok
ok friend sgcopiertech so l have code error E007 in this ir 2016 ..well l know this code error consisted the heather section parts ..so l try controled this section but it must good ..for this reason l need inisialized this copiers ..please can you tell me how can l do inisialized there ..l'm waiting ..Comment
The E007 does not have to do with the heater,, it has to do with film movement. If the film has shifted, or shredded, that is why the E007 occured. Good luck, it is usually chewed up too bad to fix.
additional functions
2, then 8
#12 CLEAR
Err"Once a King, always a King, but once a Knight is enough!"
ok friend mrfixit l will controled the film ..it is better ..l search how can l inisialized this ir 2016 ....Comment
hi...to initialize the canon IR 2016.....go through the service mode
additinal function+2+8+additional function..move by arrows to clear press ok then move to all press ok the machine will restart..
007 this malfunction related to fuser film movement
so you have to check the film& the film speed sensor...
by the way intializing the machine will never solve the system error 007...
thanks...
