Another Fax question. I'm getting a lot of No good's (##018) from this fax. It is an extremely active fax, doesn't sit idle for more then 5-10 minutes all day. In case the line is busy, I have the retry set for 10 times. They aren't sure if they were using both lines or not in the other building but it does have the capability for dual lines. Anyone see the ##018's before? Would having them add a second line help?
Finally some issue not related to free SST, firmware or bad HDD..
