Canon ir C3220 fax install instructions
  • kuby
    • Oct 2007
    • 1409
    Anyone have the instructions that come with the fax kit for a iR C3220. Got my first one in and no instructions with it. Got everything hooked up I think, but no speaker volume. The speaker is connected, and it faxes and receives. Volume is turned all the way up. But with out the instructions I can't be sure I have everything plugged in and turned on.
    Ronald
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    I do not remember doing anything special for the installation, just plug in everything and go.
    Hit the "on hook" key to test your speaker, you should be able to hear the dial tone. If you can't hear anything you may have a bad speaker, wouldn't be the 1st time (One I was able to repair a broken wire where it attaches to the speaker).
    The service mode for the speaker is Fax>Menu>006.
    0 is on from dail to connect.
    1 is on from start to finish.
    2 is on for 2nd phone line.
    3 is set to "off".
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Ronald
      Hi Kuby,
      It must be fax day! I did this one to myself, so I recall it. The red/black wire is not plugged into the proper connector above and to the right of the fax board. There are 2 similiar plugs in that little bundle coming off the machine harness up there. Seek, and 'ye shall find!
      Happy Thanksgiving Ronald!
      • kuby
        • Oct 2007
        • 1409
        Thanks for the reply. Someone emailed me the instructions and I found the little two wire connector. There was not a black adapter to connect the two plugs together, that was why I missed it. Had to rob one off another machine.
