iR1024 USB Scan driver
  • pga
    • Jul 2009
    • 67
    Dear all,
    Where i can get this model scan driver? Is this model can support USB scan? I want driver which can suppport Win2003 server. PLS>>>>>>>>>>>>>>>>
  • meme
    • Jul 2009
    • 10
    scan usb
    hi.
    yes you can just install the drivers for the IR1024, and then go to control panel ,click on the scanner icon and install it.
    • meme
      • Jul 2009
      • 10
      missing info
      sorry .
      on the canon.com you have the drivers for your printer.
      • pga
        • Jul 2009
        • 67
        I still not able to get the IR ToolBox which support Windows 2003 server via USB cable......pls advise...........
        • CanonHPTech
          • Apr 2007
          • 234
          I wouldn't expect the scan tool program that comes with the machine to support Win 2k3. Let's think about this for a second, this machine (unless it is the i model that supports Universal Send) only supports scanning via USB. Why would anyone want to scan things directly into their server? This would entail installing the buggy, consumer based, scan tool program on their server. Their print drivers do support Win 2k3, but this make since since people may still install the print driver on the server so many users can print from their pcs while the queue sits on the server. However, just a quick search on Canon's user and service sites produced no hits for an updated scan tool program. However, just as a quick note, if you feel it is not a software problem, at least the 1023/1025's firmware has been updated quite a few times in last month or too. As far as the 1024's I am not sure since I am in the US. Good luck, let us know if you find anything out.
          The glass maybe half full, but less is more...
          Printer + Fax + Copier = Jack Of Many Trades,
          but Master Of None
          Color Copier = Not A Color Printer
          InkJet MFP = Not A Fax Machine
          B/W Copier = Not A Press
          Finisher = Deal Closer (salesman, not accessory)
          Copier Tech = Admin's Stress Ball (Scapegoat)
          • pga
            • Jul 2009
            • 67
            I'm understand what you means but the customer have a very limited space and they want directly connect the machine via USB especially the Scan features.
            What i should do on this matter?
            • bipc
              • Sep 2009
              • 194
              Life is a learning continuum...
