Canon iR2800 Turn off Fax Auto Rx?
  • mrfuser
    • 1622
    Does anyone know how to disable the auto rx on the Canon iR2800 Fax system?
    I have searched through all service manuals, user guides, forums, etc. Client needs it turned off. Only uses it for outbound.
    Thanks!
    Kelly
  • alex@wocltd.com
    • 430
    just set to manual rx
    • mrfuser
      • 1622
      Auto Rx
      Gee ya think Alex?
      Where would YOU go to do that on an imagerunner 2800?
      Kelly
      • charm5496
        • 2387
        Being "pissy" with someone who is trying to help you isn't they way to make friends now Mr fuser.
        Look under additional functions>communication settings
        you should be able to find the RX adjustments in there.
        Of course this is an older machine and I haven't looked at one in several years so I am not 100% on this.
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          Can't find anything on manual RX either.
          I would try setting a password for RX or set the T1 timer to max. It should ring like 12 times before it will answer, hopefully most fax machines will give up after 5 or 6 rings.
          Go additional functions > system settings > Communication settings > Receive password. Enter some ridiculous password.
          Enter service mode > Fax > #3Numeric Param. > 11. Set it to 9999.
