canon ir550 scanning lamp stays on and wontn move
  • pinetree
    • Aug 2008
    • 33
    canon ir 550, when turn main switch on, mc goes in to sleep mode, I had to hit on/off switch and it starts to warming up, after mc warms up and ready copy mode, hit copy, the scanning lamp turns on and won't move for scanning and lamp stays on, anybody please help....
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    I have not seen this before but I would try replacing the scan lamp. Also check your front door interlock, there is a laser shutter near the interlock and this can cause the paper to sit at registration and copier just runs indefinitely or E100's. Bend the interlock so it moves the shutter more when door is closed. I think there is some legal issues in removing the shutter or wedging it open permanently soo whatever you do don't do that.
    Also this model has an interlock switch for the copy glass. Check that it is working properly. Usually all the orange lights flash if that has a problem though, but it's worth a shot.
      • 23009
      I agree with DLP. Most likely your exposure lamp is not reaching the desired intensity for any number of reasons. Some very simple, others more complex:
      Low room temperature makes the lamp dim or flicker.
      Failed lamp heater makes the lamp dim or flicker.
      Bad lamp.
      Bad lamp inverter.
      Bad CCD.
      Start with the simple stuff first. =^..^=
      • pinetree
        • Aug 2008
        • 33
        Thanks for reply and suggestions, I will try that and i will inform with results...
        thanks and have wonderful day....
        • 20YRSEXP
          • Oct 2008
          • 281
          If not the lamp the heater blanket is a good bet.
          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
          • 20YRSEXP
            • Oct 2008
            • 281
            One other thing I would try is unplugging the finisher and see if it makes a copy.
            • pinetree
              • Aug 2008
              • 33
              thanks again, I m currently out of town and had not got a chance to check this mc yet as soon as I checked it out I will be inform..
              thanks
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                As to the lamp heater suggestion,, I have some of mine over time shift on the lamp tube, partially obstructing the opening on the lamp. These usually code for me, but it is something to consider.
