Hi Freinds, I need your help regarding my Canon iR2018N copier machine problem. In the last week, this machine was giving E007 error. So according to error, I had checked machine and found that the film was damaged. Therefore, I went to market and I bought compatible film & fixed the same. The delear [from whom I bought the film] has given me Brown color and HP 5000 series film. He said that so many copier technicians purchased the same type of film and fixed into their copier machine. So I came with the same film and fixed into the same unit & tried to get the machine into working condition. But I am facing the same problem still even after changing the filem. Then I took out the unit from machine & I found that it is not heated. It was totaly cool like cold water. As per my knowledge it should heat. So I am confused what do now? Cause after these steps I had discussion with the same delear, he said that the problem with the heater of the same unit. So please try to replace the heater only. I am waiting for suggestion and help from all of you. Please reply me to this thread or if possiblem you can send me a mail on patil_ps@yahoo.com or pramod.patil1803@yahoo.co.in. Please do reply.
Your co-operation will be highly appreciable.
Thanks in advance.
Pramod.....
Thanks in advance.
Pramod.....
