Canon iR2025 displays "waiting"
  • wekek
    • Jun 2006
    • 22
    Hi all, i got a problem in iR 2025, you can only see "Waiting" display on the panel...and nothing is happening, anybody can guide me please....thanks.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Check the Fixing unit. Is it getting hot?
    Some techs flash the machine as well to resolve such issue.
    Try reseating connectors on the DC controller.
    • wekek
      • Jun 2006
      • 22
      man, i removed everything and re-install it, during initialization the canon logo and the progress bar will continue then "waiting" appears on top left corner, and that's it...stays like that. I did not flash it, initialization doesn't reach the fixing......i'm gonna try the sdram...will report back.
      • wekek
        • Jun 2006
        • 22
        not the ram.....any ideas?
        • THUK
          • Jul 2008
          • 195
          hi,have you tried an all clear in service mode.
          • wekek
            • Jun 2006
            • 22
            i cannot do anything, man....
            i tried to boot in disk scan mode...i cannot go to service mode.
            i did reseatting all the boards..
            i just dont have another machine to troubleshoot the fault.....
            anybody has an update for the usb dongle?
            maybe just maybe the dongle has a problem...
            thanks man for the reply.
            • Kopyrtek
              Copier Psychologist
              • Jan 2007
              • 407
              Sounds like you are going to have to upgrade the firmware to resolve your issue.
              • waffu22
                • Jun 2009
                • 95
                just try to replace the RAM
                • wekek
                  • Jun 2006
                  • 22
                  just did that.....ram works fine
                  • wekek
                    • Jun 2006
                    • 22
                    problem is i cannot access service mode machine stuck showing only "waiting" i leave it running for 1 day nothing happens....
                    i tried the scandisk, direct ip, nothing...goes only to waiting.
                    • hemai2005
                      Professional Print
                      • 108
                      you can solving this problem by installing the firmware
                      but tray to change the boot the first
                      sigpic
                      Learned a lot will become an expert
