Problem with my Canon iR3570 machine
  • Larry2010
    Larry
  • mrfixit51
    Lead Service Technician
    • 1975
    Originally posted by Larry2010
    Larry
    Quickest answer would be that the system software is hanging the copier during boot. Reload system software,, be sure to choose the Overwrite function in the lower left corner of SST. You may want to try the scandisk function as well. Start copier, holding down 1 & 9, It will start out with a white box in upper left corner, they will cascade down as the test proceeds. It concludes at the download screen.
    • Larry2010
      • THUK
        • 195
        hi,try switching multi broadcast off under system set up or try changing the ip address.
        • Larry2010
          can any one help me from here, and when i say i'm in over my head, i mean way way over.
          • THUK
            • 195
            hi,i might of been a bit way off with what i suggested,do you get any errors can u get into service mode do you have service support tool and software.can you swap parts to another mc to test.
            • mrfixit51
              • 1975
              I have not heard if you tried the system software reload... Do you have the tools needed to perform that task? I still believe it is your best bet.
              • Larry2010
                Hi THUK, i'm affarid no error numbers come up? i dont even know what the service mode is and i dont have service support tool or software also i cant swap parts to test.
                I think the technical term is i'm fu#ked
                • Larry2010
                  • roho
                    • Mar 2009
                    • 844
                    Call a Canon tech-He'll have the computer soft ware to reload your copier.
                    You have little choice at this point.
                    • THUK
                      • 195
                      hi,where is the mc.
                      • Larry2010
                        hi,where is the mc.
                        Belvedere in South East, London
                        • THUK
                          • 195
                          hi,ive left a mob number in your inbox to ring he might help.
                          • Larry2010
                            Cheers thats great
                            • THUK
                              • 195
                              hi, did you get hold of him to help[ you.
