Error not in Manual E 246
  • davidj7
    • 1107
    In 8500 after 1 copy I get the error E246. The error is not in the SM. Has anyone experienced this.
    a machine is only as good as your tech : source:screwtape ; the scary one
  • ymmtech
    • Jun 2009
    • 190
    Anything similar ?
    http://www.copytechnet.com/forums/ca...highlight=e246
    • davidj7
      • 1107
      thanks i found it mentioned in NAVI. still why a perfectly running machine all of sudden keeps displaying this code
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        I had an iR5055 call up E246 today.
        It's the counter pcb or at least...a problem occurred whilst data was trying to be written to the pcb.
        In my machine's case a simple restart cleared it but be mindful that it may be the sign of a defective counter pcb.
        • davidj7
          • 1107
          cleaned the connectors and the machine runs now
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Good to hear David
            • bluemax121
              • 19
              communication error
              its a camunication error
              The EEPROM on the reader controller PCB is faulty. The reader controller
              PCB is faulty.
              may cause of loose contact of comunication port between scanner and copier
              check and re connect it
              i hope it works to u
