Error e001 on canon np 6016
  • JMACARAE
    I AM NOT A TECHNICIAN. READING OTHER POSTS, ON DIFFERENT MODELS ERROR CODE 0001 IS UNIVERSAL. IS THE ONLY OPTION IS TO CALL A TECH IN TO RESET WITH CANON NP 6016? CLUES PLEASE
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Chances are you gonna have to call. This code in most canon machines refers to fuser section, parts may be needed. Plus this machine is old. Good luck.
    • davidj7
      • 1107
      in older models E001 is fuer is not reaching the desired temperature within xxx seconds. Could be fuser lamp, thermister, thermal fuse etc . I have lost touch with NP models sorry
      a machine is only as good as your tech : source:screwtape ; the scary one
      • montana
        • Aug 2008
        • 393
        'EOOl
        Detach the
        Switch the copier OFF...
        I hope it is help my dear....happy new year
          • 22999
          The E001 errors are rarely false indications. You most likely have a fuser condition that will require the replacement of the fuser, which is a little more difficult than the average enduser can handle.
          My advice? Call a tech. =^..^=
