Canon service support tool
  • teckat
    • 16083
    #721
    Re: Canon service support tool
    Originally posted by djmic
    Hi Teckat! Is this same procedure for IR advance 6255. My case was I replace the hdd of my Ir6255 because of error 602-00012 and sometimes it hangs in logo screen after turning ON. Pls help me! Thanks in advance!
    are u trained tech ???
    HDD's out of the box "Do Not Contain Printer Firmware"
    for e602, u need Printers Firmware > Canon HDD for your model > Canon SST ( Service Support Tool )
    Install SST
    Download Firmware
    Open SST> Register Printer Firmware
    Format the HDD (with HDformat file_shown in printer firmware menu) using selection of
    single mode through SST,
    Then install printer Firmware
    NOTE:
    if u receive HD Format error with a OEM Canon HDD, the
    Flash ROM PCB could be corrupted
    The part numbers for the Hard Disk Drive for this series machine have been updated.
    The new numbers are as follows:
    FK2-9008-000 iRA 6055 / 6065 / 6075
    FK4-1550-000 iRA 6275 / 6265 / 6255
    3 methods for using the CDS to update Firmware
    Method 1:
    The technician is onsite, enters service mode on the copier, selects the updater and has the machine attach to the CDS where the firmware is brought to the machine and the technician may select a version to apply and manually install the firmware.
    Method 2 :
    The Dealer uses imageWARE Remote to connect to the device and schedule a time where the device will connect to the CDS to obtain Firmware.
    The Firmware will reside on the device until such time as a service technician visits the device and manually applies the Firmware.
    Method 3:
    The Dealer uses imageWARE Remote to connect to the device and schedule a time where the device will connect with CDS, obtain the firmware and apply it automatically without any intervention of a technician.
    • djmic
      • Sep 2019
      • 6
      #722
      Install SST
      Download Firmware
      NOTE:
      Method 1:
      Method 2 :
      Method 3:
      I'm an IT technician. But just new in copiers. Thank you so much for giving me an idea on how to troubleshoot this kind of error code in this IRA 6200 series. God bless you!
      • Kraso
        #723
        Good Day.
        Could anybody send me firmware, UST and SST for Canon IR 2520? I would be really appreciate it.
        My email: lenvolg34@gmail.com
        thanks in advance
        • rere
          #724
          Hi
          I need firmware canon ir adv 6075 and 6275, does anyone have or can you tell me where to find it?
          email: rerekrnwn@gmail.com
          thank you all
          • NakSumpu
            • Dec 2019
            • 10
            #725
            Please send me the SST and firmware for ira6275i.
            My mail: sesens08@gmail.com
            Thank you.
            • jio9000
              • Mar 2020
              • 26
              #726
              Install SST
              Download Firmware
              NOTE:
              Method 1:
              Method 2 :
              Method 3:
              [QUOTE=teckat;827532] where can i get a Flash ROM PCB to purchase for a canon ira c5235a , after a pcb 1 swap from fmx xxx xxx to a" fmx xxx(001) the correct serial" because of a e355-004 ( board mismatch error) i began getting e602-0001 error , thought it was the hard drive so i tried re-flashing (HDD) Format all error" i tried a supposingly working hard drive from a similar machine , and got the same error ...i was told by another tech that the Flash Rom may have been corrupted . this may all be as a result of a pcb 1 swap from (001) pcb 1, re inserted the old pcb which was booting now i'm getting the same error
              • teckat
                • 16083
                #727
                [QUOTE=jio9000;1518793]
                It has been noted that certain refurbished Main Controller PCB 1's have a Flash Rom attached.
                Since these refurbished boards were pulled from a previous machine, the Flash Rom that comes with them might contain information about that previous machine.
                The E748, 9000 code is a system error and would indicate that the Flash Rom information does not match the information related to the particular machine.
                If there's a Flash Rom PCB installed on the refurbished Main Controller PCB 1 and the machine displays an E748, 9000 code with this board installed, remove the Flash Rom and install the one from the old Main Controller PCB or a brand new one.
                as of 2018
                The SATA-FLASH PCB ASSEMBLY is no longer available through parts and can only be provided by CUSA hardware engineering. 800-528-2830
                Flash ROM for all models:
                Counter Memory-----------------check online Google
                FM4-1259-000
                imageRUNNER ADVANCE C5235/C5235A -----------------must use this Main pcp forr 5235 model > never SWAP
                Main controller 1:
                FM0-0353-000
                imageRUNNER ADVANCE C5235/C5235A/C5240/C5240A/C5250/C5255
                Hard Drive:
                FM0-0318-000
                • omater
                  • Oct 2020
                  • 4
                  #728
                  Hi. I need service support tool too.
                  I need it to reload software to IR 1023N
                  Please send me it to email: xerviteca@gmail.com
                  • charm5496
                    • 2387
                    #729
                    You do not need SST to load firmware on a 1023. It comes with it's own tool and use a USB cable. You may want to purchase a service manual.
                    • teckat
                      • 16083
                      #730
                      Adobe Acrobat
                      User Support Tool _Procedure Link
                      • RII
                        #731
                        Can you please send firmware to r2@r2creations.com for irA 6055, I have SST.
                        Thank you O Gracious One!
                        -r
                        • copier tech
                          • 8187
                          #732
                          -r
                          Happy to help, drop us an email.
                          Firmware Update - Printer & Copier Firmware
                          • Jeffram
                            #733
                            I need the Service Support Tool and firmware for an ir345. Thank you very much.
                            jeffy.ellis@gmail.com
                            • Obtex
                              • Jan 2017
                              • 22
                              #734
                              Hey. Does anyone have Canon IR2020 firmware and SST?
                              my mail - oskars@stals.id.lv
                              • copier tech
                                • 8187
                                #735
