Double Image Copies
  • prolegalcopy
    • Aug 2025
    Double Image Copies
    I have a Canon IR7095 and when I copy I am getting a double image? Can someone help
  • 10871087
    • Jan 2005
    • 1062
    Is it a just blur or is it an offset image (repeated down the page)?
    How far apart are the double images? Measure (in Millimeters) from the top of the good image to the top of the 1st repeated image. That distance will help us determine what component might be causing your issue.
    • prolegalcopy
      Double images on copies
      2 mil seperation
      if I raise and lower the corona housing it solves the problem for about 100 copies
      • SCREWTAPE
        East Coast Imaging
        • 3396
        There's a possibility that your laser unit might be the problem. I've had these go prematurely.
        • charm5496
          • 2387
          you need to upgrade your machine to version 78
          and send your laser in for repair or get a new one.
          There are major issues with that laser unit and the diodes.
