Canon Faxphone L80
  • cucuklotz
    • Mar 2007
    • 611
    Canon Faxphone L80
    I have 2 customers whose machine does same thing,with one complaining about it.They boththrout day say"Recieved in memory,check paper size"If you hit Stop button machine will print fax from memory,sometimes 1 job sometimes 2,even 3 jobs and then at somepoint stopping where same message appears and you have to prompt again by hitting stop button.I thought at first it was feed issue,but machine feeds perfectly when you prompt it thru stop button. Any help would be welcomed..
    THANKS, ANDY
  • mrfixit51
    Lead Service Technician
    • 1975
    Are some of the pages split into two pages? It sounds like it does not know how to deal with longer paper maybe,, I am fax blond, but I know that you can set up the bigger guys to handle longer pages thru some vertical compression settings. Not sure how it is done on the faxphone though.
    • cucuklotz
      • Mar 2007
      • 611
      Canon Faxphone l80
      thanks for reply,it is not a size issue as faxes recieved are 8.5 X11 and no split sheets and all print fine when you press stop it clears the check paper size message. This may be common problem of something not set right on these models.
      Andy
        • 22999
        Are you sure that the correct record paper size is programmed in?
        Go to Function, Data Registration, ^ or v to Printer Settings, Set, ^ or v to the appropriate paper size, Set. See pg 39 of the Basic Operators Guide.
        • cucuklotz
          • Mar 2007
          • 611
          Canon Faxphone L80
          HI,
          Thanks for info.Ill try today. And THANKS FOR ALWAYS offering help .You are a big part of why this board is so successful.
          ANDY
          • cucuklotz
            • Mar 2007
            • 611
            canon L 80
            THIS IS A PS
            I forgot that when I ran a printout yesterday of user data,the paper size did say Letter size was set in default. I hope this additional info helps
            Thanks Andy
            • mrfixit51
              • 1975
              Still might be a compression thing. Set up the device to vertically compress to say, 75% when needed. I have seen where even a 11 inch sheet has stuff too close to top and bottom that triggered this problem.
              • cucuklotz
                • Mar 2007
                • 611
                Canon l80 Faxphone
                Ill give the compression solution a try.
                THANKS ANDY
                • mmechura
                  • May 2008
                  • 43
                  rx errors
                  I have seen similar problems, what you should try is turning off ECM on both RX and TX. This fixed my clients issues that were very close to what you describe.
                  • cucuklotz
                    • Mar 2007
                    • 611
                    Canon Faxphone L80
                    thanks for ECM insight. I was wondering about that.
                    ANDY
                    • cucuklotz
                      • Mar 2007
                      • 611
                      HI again.
                      I shut ECM RX setting to off,but still have same issue, The faxes are in memory and can only be printed by hitting stop button for each new fax in memory.The Check paper size is also on(the machine is set for11 inch paper)when prompted for each new fax in memory it feeds fine so Im thinking some setting needs tyo be changed. Is some problem causing faxes to be put in memory(Toner is good and paper is in tray and feeds fine)And how come each new fax recieved needs to be printed by pressing stop button,shouldnt they feed consequentlyout even if there was a problem thatt vput it there in first place. Any help would be appreciated.
                      Thanks Andy
