IR 5000 mailbox
  • ultramagnus
    • Aug 2025
    IR 5000 mailbox
    Hi,
    Can anybody tell he how to copy the content of IR 5000 mailbox to the computer?
  • ymmtech
    • Jun 2009
    • 190
    Print out and scan to computer.
    • Irish
      • 110
      you need to use the rui .. open the rui on your pc .. on the left hand side you will see additional functions and somewhere in there it will allow you to export mailbox to a saved folder .. onc you have it there you can import it back to the copier or to other copiers.. Always worth saving it in case you loose the hdd
      • SCREWTAPE
        East Coast Imaging
        • 3396
        You might need the Jbig Veiwer plugin.
        • ultramagnus
          Thank you all for the advice,
          @ ymmtech :
          I am looking for online back up
          @ Irish :
          I have tried using the RUI, but via RUI it can only move/copy files between folders in the mailbox, it cannot transfer to the computer.
          Maybe am I doing it wrong?
          @ SCREWTAPE :
          I also have tried The JBIG plugin, but it can only save the content page by page. Does the JBIG able to save all page at a time?
          Does anybody has other solution?
          • ymmtech
            • Jun 2009
            • 190
            Do you means that you need a feature that enable you to use computer to copy mailbox contain and paste to anywhere as what we can save a web page picture?
            • Irish
              • 110
              I am talking about the mailbox address books.. I do this all the time so i can install on other machines in same location.. If you mean what has been sent or scanned to mailbox addresses Then that is not possible (as far as I know) sorry if I misunderstood
              • ultramagnus
                sorry my English is not good. If it is consfusing please ask.
                What I mean is, after scanning books/documents, I save it in mailbox - user inbox (00, 01, ..). Now I need to copy the user inbox (for example user inbox 01) to computer. I need to copy it into FlashDirve, and restore it to other machine. Is it possible? What should I do?
                Thanks a lot.
                • costd
                  • Jan 2008
                  • 409
                  Far as I know, Canons cannot copy the contents of a mailbox to a memory stick. The guy above that mentioned printing them out and then rescaning them is the only way I know.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    @ SCREWTAPE :
                    I believe this is the only way to view it on a workstation. You can not batch scan. There are some models that use the JBIG Viewer to view pages scanned into the mailbox in the RUI. They store the scanned mailbox files in JBIG format. Other models only store thumbnails, not the full JBIG files when scanning documents to a mailbox. You will not be able to save a thumbnail with the JBIG Viewer.
                    Only newer model support and feature to import/export from USB sticks. Costd gave you the best option> Print them out, scan them back. The only other option you might have is.. To buy a scanner, that way you can scan and print.
                    This is not gonna work. Let alone the image file format. I believe its a tiff file?
