Canon iR6570
  • Juelis
    • Aug 2009
    • 20
    Canon iR6570
    Hi again guys!
    I have a Canon 6570 that when shot by ADF copy format A4R it cuts the image. The picture comes out the bottom right corner of the paper. I realized that it recognizes the original in A3 format.
    Already changed the ADF and changed all the options related to the ADF that I read the manual.
    But it did not work
    Does anyone have a clue there?
    I thank you guys!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    For the hell it , get into service mode and change the value in Level 2/ Copier/ Option/ Body SENS-CNF = 1
    • Juelis
      • Aug 2009
      • 20
      Screwtape
      I did the procedure you now, but I'll be honest. I made the change, hung up and turned on the equipment and only the first copy came out right. After the problem continued. oO
      Thank you!
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Maybe you have a bad reader controller pcb.
        • bakaoni666
          • Mar 2010
          • 56
          i've this trouble too. it always read A3.
          • Juelis
            • Aug 2009
            • 20
            Solved!
            Man, I solved this problem.
            In my case, after changing all the settings, I thought it might be a problem with the sensor to recognize the A3. But it was only dirt.
            So in my case it was only open the lid that is the recognition sensor A3 and clean the sensor.
            Me only a few had not blown out. Then disassemble, clean and see if it works.
            Good luck!
            @Screwtape
            Thanks for help!!
            • teckat
              • 16083
              Good luck!
              @Screwtape
              Thanks for help!!
              great fix
              • SCREWTAPE
                East Coast Imaging
                • 3396
                @Screwtape
                Thanks for help!!
                No problem any time.
